Hi. I just finished building a full custom loop watercooling using Alphacool parts:
My GPU (3080ti) is cooling great! If I run FurMark stress test, the temps level off at around 64°C with 50% fan speed. This further confirms that everything is fine with my loop and the pump is adequate. I am very happy with it. 340W GPU power, at such temps, amazing!
My CPU (AMD 5800X3D) ... however ... does not seem to be doing well at all.
Idle temps are quite high, around 60°C. As soon as I start any demanding CPU workload (for example, a Blender CPU render), the temps immediately jump to 90°C and the CPU throttles. If I touch the radiator and the tubing, they do not feel warm at all.
Based on these symptoms, and the fact that my loop is otherwise working fine (given my GPU temps are great), I suspect the issue is with the CPU heat transfer into the waterblock.
I tried everything I could think of. I reinstalled the CPU waterblock several times. Less thermal paste, more thermal paste, less mounting pressure (not tightening the screws to the end), more mounting pressure (tightening them to the max), ... I tried liquid metal (Thermal Grizzly Conductonaut), which I have successfully used on other systems and like very much ... made no difference. I tried different thermal pastes. I even tried lapping the CPU IHS (1000 and 2500 grit sandpaper). Tried changing the orientation of the waterblock. Nothing makes any difference.
The CPU spikes to 90°C and throttles under multicore load, no matter what I do. It behaved better with an air cooler. I used an air cooler on this system before. The temps used to be 80-something °C at max fan speed and no throttling. I thought the watercooling would be an upgrade. But it's not working it seems.
Any ideas? Maybe something is wrong with the waterblock itself?
EDIT: also tried a different pump: an old Laing DDC pump I had laying around (bought from EKWB many years ago). Much more powerful than my new Alphacool DC-LT 2, much more flow, but still no improvement to CPU temps.
- Eisblock XPX CPU Block
- Eisblock Aurora Acryl GPX-N RTX 3090/3080 (for Reference 3080ti)
- NexXxoS HPE-30 Full Copper 240mm Radiator
- Alphacool DC-LT 2 - 2600rpm Pump
- Eisstation 80 DC-LT Pump Top + Reservoir
