• Dear forum members,
    due to an illness of one of our support staff members, we are currently only able to respond to support requests in the forum to a very limited extent. Please contact info@alphacool.com directly with questions about the order status or cancellations.
    Thanks for your understanding.
    Liebe Forenmitglieder,
    aufgrund einer Erkrankung eines Supportmitarbeiters können wir im Forum zur Zeit leider nur sehr eingeschränkt auf Supportanfragen reagieren. Bitte wendet euch mit Anfragen zum Bestellstatus oder mit Stornierungen direkt an info@alphacool.com.
    Danke für euer Verständnis.
Suitable Water block for Gigabyte 2070 Super windforce OC
eschbow
Hey guys. I want a waterblock for my graphics card (GV-N207SWF3OC-8GB) but i am not quite positive if it sports a Reference PCB. I have read some stuff about the cards PCB is similar to the Reference PCB of the 2080 so blocks for them should fit fine. Anybody with knowledge about the PCB here?
Thx in advance.
Vanzin
HI,
I am sorry but we do not have any information about this PCB Layout or do you mean GV-N207SWF3OC-8GC?
If your PCB number is correct we would kindly ask you to send us a photo of your GPu without the original cooler so we can check the PCB Layout for you.
eschbow
HI,
Yes, it's this card. Do you guys have a Block for it? Your configurator only shows a Block for the GV-N207SGAMING OC-8GC
Vanzin
HI,
sure for this GPU is using the reference layout. For this we have following water blocks in our assortment.
eschbow
HI,
Thanks a lot, mate!
fortyKnoxy
I have a similar problem. My GPU is GV-N207SWF3OC-8GD. I compared the GV-N207SWF3OC-8GC with my GV-N207SWF3OC-8GD on Gigabyte website and seems to have dimensions difference. So is there a watercooling block for my GV-N207SWF3OC-8GD? Thanks in advanced.
Vanzin
HI,
I am sorry but for the GV-N207SWF3OC-8GD we do not have an water block in our assortment.
fortyKnoxy
Thanks for the answer but I don't understand, why doesn't fit the one from GV-N207SWF3OC-8GC? The difference is this:
1. GV-N207SWF3OC-8GC
L=280.35 W=116.45 H=40.24 mm
2. GV-N207SWF3OC-8GD - my card
L=286 W=114 H=50 mm
or there is also something else? Thanks for the help.
It is less about the size of the PCB than about the position of the components on the PCB. It is enough here if some components differ in height or position by 0.5-1 mm, then the cooler no longer fits. So we scan all PCBs to get the right 3D data to position the cooler exactly.
Any chance to get a pic from the PCB of your card? Maybe we can check if we have another cooler for you.
S3v3n7
I agree what "fortyKnoxy" said. I have similar problems with my graphic-card. I bought the GV-N207SWF3OC-8GD too. I bought this one "https://www.alphacool.com/search?sSearch=11683" and it "works" ... a bit. The problems are not the length or any of this. There are capacitors on the end of the card. That is the main problem. It's not the best option... i know. But it's not my first plate from Alphacool. I bought this one "https://www.alphacool.com/shop/graf...0/2070-super-m01-mit-backplate?number=1015871" a few days earlier. What should I said I tried this one too and it not works.
I hope I am helpfully for you guys from Alpahcool.
Ps: Sorry for my english.
Vanzin
At the moment we do not have a water block for this GPU in our assortment. We are currently checking if we will produce one for this PCB Laoyut but I can not say it for sure at the moment and if we will produce one the earliest relase date will be in 3-4 Month.
Thoger
As I'm looking for a waterblock for my GV-N207SWF3OC-8GD as well, I would appreciate if there would be an alphacool solution within the next 3-4 month :)
Vanzin
HI,
I can tell you that we will produce one for it. I think it will be available in 3 up to 4 month maybe earlier but that can I not say for sure.
ChadXSO
Looking forward to this :)
Will it also apply to this model: GV-N207SGAMINGOC WHITE-8GD?
I think it will because I believe it is just a white version
Please confirm?
