Hey there!
When I fully fitted the alpha cool 13429 (as recommended by hwconfig) I noticed there was a .6-.8mm gap between the VRMs. The rest was fine (memory/cpu).
I’ve temporarily placed some spare pads I had (not satisfied I placed 2 pads together to bridge the gap) as the 1mm +1mm would be too thick. I also placed some squishy blue 1.5mm (Sabrent m.2 nvme thermals pads) between the 4 VRMs not covered on your instructions (closer to the gpu) to be sure of contact afterwords.
There may have been a revision change done to the KFA2/GALAX RTX 4090 SG-1
Could you please advise which thermal pads I should use, the ones I was looking at (gelid 120x120x1.5) is already £42 .
Kind regards
Bish
(I’ve posted a resized image of the gpu, your site couldn’t handle the larger high res picture)
Kind regards
Bish
