• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
Terminal Rotary 90°
Testifier
Greetings.
Do you guys have a 90 degree block terminal for the 3090 fe block? Specifically for the one with the inlet/outlet at the end?
Something like this
For this?
Alphacool_Eisblock_Aurora_Acryl_GPX-N_RTX_3090_Founders_Edition_mit_Backplate_1020498_01.jpg
Thomas_S
Administrator
I have no idea what you're going to do with it!? ;-)
We don't have anything like that in our range.
But we have enough fittings & connections with 90° & rotatable.
Testifier
I need the exact 1-slot config of the waterblock due to space constraint. The normal terminal angle plus the fitting would make it into 2-slot spacing
Exactly what I am looking for. Can you confirm that this terminal would fit the 3090 FE block I post above?
Yes, that terminal is made for all Eisblock Aurora GPU blocks. So all Nvidia RTX 3XXX and Radeon RX 6XXX blocks.
