To which case I can fit Alphacool Eisbaer Aurora 420 to land in on top?
eldzr
Im wondering which case shoul I chose, my first chose was be quiet! Silent Base 802, will it fit or should I used other case?
Metropolis34
You need to measure it out really. You can ask also Be Quiet for the dimensions or size of the case.
Thank you.
