Top With More Than One G1/4 Port For Core 100 Aurora reservoir
pioneersti
I'm using the Alphacool Core 100 Aurora reservoir (15380) in my loop. I would like to switch the inlet to the top (using the short tube), but the top only has one G1/4 port.
Does Alphacool make any optional tops with two (or more) ports that will fit the Core 100 Reservoir?
If not, are there any aftermarket companies that make one?
Vanzin
Hi,
we don´t offer an different Top for this reservoir and we also don´t recommend to use the fill port as Inlet. THe problem is that if you use the fill port as inlet the air will move back in the loop. The only option to pretend this is when the top tube is completely under water.
