Marshal Poppins
Hello,
As the title states I've just set up a loop using the Eisball reservoir and would like to use its RGB function to indicate CPU temp. My Asrock mobo has the appropriate header but their software only supports cosmetic nonsense. I also have a Corsair Commander Pro, if I can get it to recognize the Eisball, it does support linking the color to component temp.
I have tried: https://www.amazon.com/dp/B08KGMZ9YT/ref=cm_sw_em_r_mt_dp_V24DVV5KN5VKHKN6X2S0
But I could not get it to work for me. This is a shame as I think using the Corsair hub is probably the best option.
Any thoughts?
Thank you.
Any thoughts?
Thank you.
