D
Deleted member 488
Guest
Hey guys. I am about to install a EK D5 X-Top upon my Alphacool VPP 755. As the 755 has about the dimensions of the D5 the top should fit just fine. Now i have the problem that the o-ring provided by the pump (blue mark) alone fits fine and t can screw both parts together with ease. But the pump wont start after all. I have to losen the screws so far that water sips through the gap.
The manual of the top says i should use the provided gasket that comes with the EK top (Red Mark) . Doing it that way, i can't screw the top together tightly and Water sips through by only filling the reservoir.
Any one of you guys maybe has an idea?
Thx in advance.
Thx in advance.
