VPP655PWM Bypass PWM cable for 100% speed
madlan
Is it possible to set the PWM to 100% without using a motherboard connection by supplying 5v to the PWM green wire for example?
Metropolis34
Hi, 100% is 5V so you can ONLY use it at 0 or 100%. For everything between you need PVM Generator/Mainboard/Controller.
