Cre8 Modding
Active member
For 2023 I am kicking things off with a build in the new Hyte Y40, I've previously built in their Y60 and I thought it would be nice to follow that one up with something similar.
Hyte was kind enough to send over a white version of the case and on first impressions, it looks lovely! I will be throwing a full hardline system in this with the following;
MSI Z690 Carbon Wifi
Intel 13900K
32GB of TeamGroup Vulcan DDR5 5200
RTX 3080 Founders Edition
be quiet Dark Power Pro 1200W
Seagate FireCudas 520/530 approx 10TB total
I will get to those main components later as they are still mixed between other systems. The Alphacool parts are on their way, and again thank you to them for supporting this build, when they arrive I will throw some photos up. I'm quite excited as I will be putting in one of Alphacool's new Core distro plates to the side area of the Y40. I am a little concerned about how deep this is going to be though, a 30mm rad, fan, and then the distro in front of that so it will step out a lot from the rear of the case.
Until the water-cooling parts get here though, here's some shots of the Y40!
Intel 13900K
