iamgianluca
Hi,
I currently own a Gigabyte RTX 3090 Turbo and add a second one later this year, as soon as prices become more accessible. The GPU is too loud for my taste, so I was thinking of water cooling it. The GPU runs at full load pretty much 24/7, as I'm using it to train machine learning models. I've currently power-limited the GPU to use max 280w instead of 350w, as the performance degradation is minimal (~5%) whilst the heat generated is significantly less ― which also helps keep the GPU's fan to a more bearable noise level.
If I go for a water cooling solution, I see two options:
My ultimate goal is to have a quiet solution and does not incur thermal throttling with a system running at full load pretty much 24/7. I would also love to keep maintenance to a minimum.
Many thanks,
Luca
- Custom loop:
- What pump, reservoir, and radiator should I choose to cool 2x3090 running at full load 24/7? I would pair those with 2 Eisblock Aurora
- 2 separate AIOs, 1 for each RTX 3090:
- Can an AIO solution like the Eiswolf 2.0 take care of a 3090 running at full load 24/7?
- Can an AIO solution like the Eiswolf 2.0 give you temperature comparable to those of a custom loop? If temperatures are comparable ― maybe just a few degrees Celsius away ― I would be glad to reduce maintenance to zero for go with 2 AIOs
Many thanks,
Luca
