Hi, I created my first water loop system with Alphacool Eiswolf 2 AIO for my RTX 3090 and Eisbaer 420 for my CPU, since the loop was big and the pump power wasn't enough I added a D5 pump to the loop which helped to cool down the temps a few degrees more. The d5 pump was a combo with a res. To fill the res I purchased an Eiswasser crystal clear. after turning on the PC the water turned murky white immediately. I thought maybe the water in the radiators wasn't clear so I flushed the system twice and purchased another coolant. The problem remained unsolved. I thought maybe this is the problem with the coolant so I purchased another coolant from corsair this time. Again I flushed the system and turned it back on and as you can guess the coolant changed color immediately. I searched on google about this issue and I found out this is a problem when mixing aluminum radiators with copper ones but as it is indicated on the Alphacool website both rads are full copper base. I'm really confused and out of ideas. I appreciate any help as I'm worried that some kind of corrosion is happening in the system.
Best regards
Best regards
