I bought Asrock x570 Phantom Gaming ITX TB3 motherboard and yesterday I received my case, Streacom da2.
I decided to buy alphacool’s eisbaer 240, it comfortably fits in the mobo but I have a problem fitting it inside my sff case.
Cooler's height is 87mm, plus radiator with fans 55mm, 142mm overal.**
Streacom mentions 145mm cpu max height.
**The problem is that I did not calculate the extra space of the tubes.
I think, correct me if I am wrong, that fittings can be exchanged easily.
So:
- I want to reuse the existing radiator
- I want to reuse the existing tubing 11/8
- do I only need to buy 2x 90 degree fittings (using G1/4” threads)??
Result
67.5mm cooler
31.4mm 90 degree fitting
30.0mm radiator
15.0mm fans
143.9mm (out of 145mm)
But is this the right fitting? In Product Information mentions:
The 11/8mm fittings are compatible with 10/8mm and 10.3/7.5mm tubing
Really appreciate any help
So:
Result
67.5mm cooler
30.0mm radiator
15.0mm fans
