240mm Alphacool Eiswolf 2 AIO RTX 3080/3090 Gaming/Eagle with Backplate
Loldemort
Hi
I'm looking to buy an AIO for the GPU. I have found one compatible with my Gigabyte RTX 3080 Turbo in the store. The problem is compatibility with my case.
I have a CoolerMaster NR200 case which does not support 360mm radiators. I was wondering if that specific AIO (Article no. 14416) could be bought with the 240mm radiator instead of the 360mm.
Also, I have in my case a Nocuta NH-D12L cooler for the CPU and I'm wondering if anyone knows if I can mount the radiator with the fans in the case.
Thanks
Vanzin
HI,
I am sorry but we donßt offer customize products. If you want a smaller radiator, you have to purchase one separately and replace it by yourself. Please also note that we at least recommend a 360mm radiator to handle the heat from the GPU.
