AM5 Performance kit original screws do not fit
Gareth Blundell
Hi,
So I have purchased the AM5 performance kit and the instructions outline the use of the original motherboard AM5 mounting screws that came with the motherboard to mount the kit to the bracket. Problem is these screws will not work as the head is to big and prevents any thread passing through. I am aware others have had this issue as I saw it on a discussion somewhere but now cannot remember where I saw it. For reference my motherboard is the MSI X670E Carbon WIFI. If anyone could please point me in the direction of the correct screws I need to get I would be really grateful.
Vanzin
HI,
due the high tolerance of UNC screws, it can happen that the original screws doesn´t fit. Please contact our support (info@alphacool.com) to get compatible screws for free.
