Where did u get this info? I just checked tech data and both edge and non edge blocks are nickel plated copper. But yes edge version looks nicer thoI'd get the Edge because it's brass, and the regular Aurora is Aluminum. Not that that's bad but it can make a difference. Just make sure if you use mixed metals in the loop you have coolant with good corrosion inhibitors.
Both are brass cooler. Where did you found the info that the normal is Aluminium??? We dont offer any parts where aluminium is in touch with water. Only full Aluminium radiators for industrial customers.I'd get the Edge because it's brass, and the regular Aurora is Aluminum.
My bad. I don't know how I got that. I probably looked at the wrong datasheet. The Edge is nicer though.Both are brass cooler. Where did you found the info that the normal is Aluminium??? We dont offer any parts where aluminium is in touch with water. Only full Aluminium radiators for industrial customers.
