Eiswolf for EVGA GeForce RTX 3090 Ti K|NGP|N HYBRID
chris1601
Hi everybody,
I'm thinking about possibilities to replace the cooler on my EVGA GeForce RTX 3090 Ti K|NGP|N HYBRID model nr. 24G-P5-4998-KR.
The pump is making a fairly loud humming sound and I’m afraid it got to get worse. Unfortunately the card is an Amazon retour purchase and I’m not thinking there’s any warranty left. but I will try to RMA the card with EVGA.
In the meantime, I’m looking for other possibilities to cool the card. Does anybody know if the
Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI FTW3 with Backplate Article no.: 14478
will fit the Card?
Your advice will be highly appreciated
Thanks Chris
Vanzin
HI,
I am sorry, but we don´t have any information about the used PCB Layout of this GPU. If you send us a photo from your GPU without the original cooler, we can check if we have a compatible water block in our assortment.
