Performer81
Good day
I ordered the Eiswolf 2 AIO water cooling for my MSI 4090 Suprim X from you. For the front, the PAd for the single Ram module next to the GPU was missing and one pad was also white instead of gray like the others?! Luckily, I had 1mm PAds from Arctic left over for the single ram module, which I then used. GPU temps are now rather mediocre, in the mid 60s range for GPU, hardly better than before, ram-like.
Assume that the GPU does not have 100% correct contact pressure.
The screenshot was taken after about 10 minutes of full load Port Royal benchmark, GPU temp then already short to 70 degrees. System 5 pump is the pump and CPU_opt is the fan speed of the radiator. The benchmark starts at about 50 degrees and then rises continuously. The radiator blows outside. I wouldn't like to let fans run faster because they get loud.
Are the temps normal or is there something wrong? on the net I often read about max. temperatures in the mid 50s.
