I set up this loop about 3 months ago. I noticed there appeared to be a white particulates floating on the top of the reservoir. The coolant does not look cloudy it just has something that seems to be floating on top.
when I set up the loop I previously flushed the radiator overnight with distilled water. When I put the loop together I also ran it for a couple of days with distilled water. Then I flushed it out and filled it with Alphacool Eiswasser - Premixed Coolant - Crystal Blue - UV Reactive.
Looking over the forums, I have seen this issue described as being plasticine leaching from the soft tubing in the loop. I used XSPC FLX tubing that is plasticine free and its only on the surface of the reservoir so I don't think this is the problem.
all the parts are copper ( radiator, water block ).
does anyone have an idea of what this might be? This is my first water cooling build so I don't have a lot of experience to draw on.
thanks for your time,
GF
GF
