Pump.
Alchuchone
Hello.
I got an alphacool vpp of 340 max l/h, mu loop is one reservoir alphacool 250ml, alphacool block for 6800xt sapphire, 1 rad 420mm 3omm thick and another rad bisky 360 60 thick , 100% rpm with the alphacool pump i get 150l/h, so i bought from you an aquacomputer pump d5 1500 l/h ( order number from aquatuning.es 90024260) max to get more power, and my surprise was that the new pump at 100% i get the same 150 l/h, how can this be posible?
Thank you for your time.
best regards.
Vanzin
Hi,
both pumps have the same power and therefore you will have the same water flow.
Vanzin
For this you have to contact Aquacomputer themself. As far as I know are they using a original laing/Xylem D5 pump and I can´t say why they are specificating their pump with higher water flow.
SamCoffee
It's possible that the issue lies with the pump's installation or configuration rather than the pump itself. Check if there are any restrictions in the loop, ensure proper priming of the pump, and verify if the pump speed control is functioning correctly. Consider contacting Aquacomputer support for further assistance.
