Cayan
I would like to add a more a Pump+Reservoir into my Eisbaer Aurora 360 and Eiswolf 2 loop. I would like to try better temps and make the drain/refill of the coolant easier. And of course, better looks.
Questions:
1 - A better/stronger pump into this loop will improve the temps?
2 - Should I replace the hose of the loops with a 10/13 instead? ( will that help with the temps/flow? )
3 - Should I consider also to add a 3rd Radiator? ( 3x 360mm )? Is that an overkill for a 5950x and RTX 3090 or it will help with temps as well?
4 - If I add only the reservoir, of 150ML... Are the pumps of both AIO enough to run the loop? Or do I need to add an extra pump if I want a reservoir?
5 - What Coolant is used on these loops that I have? I want to buy it to fill the reservoir.
Questions:
