WaterCoolingGnome99
I purchased the DDC pump new from an amazon seller "Doc Micro", on the 14th October 2020.
I used it for a few months. It seemed a bit weak, struggling to move liquid around the loop of a small form factor pc.
One day it failed, causing my CPU to overheat and crashing my computer.
I removed the pump and tested it outside the computer. The pump started working again.
I do not want to risk putting it back into the computer's cooling loop, as I am worried the pump will fail again.
I contacted the seller and they told me to ask you.
Could you please advise.
