Hello,
I have a 7950X and am currently using a BeQuiet SilentLoop2 AIO (360mm).
In order to reduce noise levels (and possibly temperatures) I am looking into a 4200mm CPU AIO.
As far as I can see there are three Alphacool Eisbär products available which would fit the bill:
The noise level for 1. is published in the spec (29.4dBA @ 1100rpm) but I can't seem to find the noise levels for the other two (or whether they are the same).
Is the figure of 29.4dBA referring to a single 140mm fn running at max speed or to all three fans?
My current AIO is emitting 39.8dB at full speed and a level of 29.4dB would be extremely impressive it was for all three fans.
