Alphacool Eisbaer Pro Aurora 280 CPU AIO in NR200P MAX V2
Zwizz
Hello everyone
Id like to replace my current AIO because the 280mm radiator from Alphacool
is made of copper and I'm hoping for slightly better cooling performance. The
problem is, that the CPU cooler has straight connectors. So my question is can
I simply use 2 90° connectors there? That way I should have enough clearance
for the GPU. Thanks in advance for your help.
An Eisbaer with 90° fittings on top wouldn’t be the problem, but you definitely wouldn’t be able to fit the graphics card into the case anymore because the cooler with the fittings would be far too tall.
I have ordered an custom 6cm PCIe Gen5 cable, so I can use the two
slots closer to the mesh panel and not the default ones - Do u know
the exact height prolly for the cooler inclusive the 90° fitting?
Thanks in advance.
The Eisbaer Solo is 69 mm high. As for the fitting, it depends on which one you want to use in the end. A standard 13/10 fitting has a total height of 29 mm, of which 5 mm is the thread that is screwed in. You can find the dimensions for all products, and you can also measure them yourself in the 3D Center: https://www.alphacool.com/en/3d-viewer-center
Back
