Hi Guys.
We are experiencing higher than normal temps with the XPX Aurora Edge CPU block with intel 13900KF/KS in systems when we rotate the CPU block 90 degrees. (ports vertically aligned)
Is there any official recommendation on the correct way up for these CPU blocks or is it ok to rotate the block?
cheers.
cheers.
