Alphacool Eiswolf 2 pump died
Cesar
Hi,
I have this watercooler for a RTX 3090 FTW3 and recently I'm pretty sure that the pump completely died. There are no moving water,no noise, no action,nothing! So I was searching here in the Forum and I found out a possible solution that it would be to replace only the pump. I want to confirm if this possibility would fix my problem.
https://shop.alphacool.com/shop/pumpen/dc-lt/ <<< Which one I could buy it and replace the faulty pump?
astaaa
Administrator
Replacing the entire top would be too much trouble. Unfortunately, we do not offer this top as a spare part. If you still in warranty you can contact us so we can solve this issue. Please use the following email adress: info@alphacool.com
Cesar
More trouble than I already had by completely disassembling ,cleaning and assembling again? It would be fine for me but, from what I can see, there are no possible way to just replace the pump and with the same top, the 3-pin connector would not fit in on that little space that the cable goes...
