Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 for brass tubes
grozzie
Hi,
I bought these fittings for a new build.
What is the correct order of assembly? I've tried various sequences but the fittings seem to slip off the tubing.
Product ID :-
Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 for brass tubes.
  • Article no.: 17432
  • EAN: 4250197174329
Thanks
Wich tubing you are using? That is a special fitting for brass HardTubes not for normal tubes.
grozzie
Alphacool HardTube brass black chrome.
I want to know the order of the 3 internal parts to this fitting i.e. the flat black ring, the brass ring (with cut) and the silicone 'O' ring. Also the brass ring is chamfered on one side, so which way up does this go.
Thanks
We have a German proverb. I don't know if it makes sense in English: Sometimes you can't see the wood for the trees! :)
