Are these fans fully addressable when dasiy chained or will they only mirror data to next fan.
If I connect 8 fans together can I fully address all the leds on all the fans or is it a case of 1 fan per channel on controller
Hi, if you connect the fans to our controller it mirrors the data to the next one and they show the same effect. As far i know there are controllers on the market which can separate this function so you can control every single fan.
That's not what I want mirrored data, if I put the fans in series 8 of them on 1 channel will your fans fully address the leds all of them on all 8 fans, or are the fans like ek ones and only support mirrored data
