Alphacool presents the Fan Shroud & Decouplers for 120mm and 140mm fans, a must have for performance orientated liquid cooling enthusiasts. These silicon shrouds improve the performance of your liquid cooling system by optimising the airflow through the radiator. The "dead spot" under the fan hub is overcome as air pressure builds up between the fan and radiator. The airflow is forced through the fins of the radiator as well as preventing air from escaping through gaps. This in turn also reduces the noise created from the escaping air as well as acting as a decoupler to dampen the vibrations being transmitted from the fan to the radiator and potentially to the case.
For more information click here: Alphacool Shroud & Decoupling 120mm & 140mm
