Cooler argb on eismatrix II
Spookysmoke
I have an eisblock xpx and eisblock gpx both have a 3 pin argb head both m/f but are both to big to fit the 3 pin connector of the eismatrix II
Im I just doing it wrong?
Do they simply not fit? Pictures on the eismatrix look the same as the connectors.
Is there some kind of adapter if they don't fit?
If im running all my cooler fans through the eismatrix should i plug the fan connector to cpu_fan
Metropolis34
Hi there, you need to use the adapter which is included to the Eismatrix with the JST connector 4 Pin adapter PWM for fans has also a 3 Pin connection. (3Pin 5V / 4 Pin 12V this information is also available at the product description)
There is only one adapter cable included to the delivery. If you need more of them you can buy it seperatly;
Spookysmoke
I was more asking about the 2x 3 pin connection at the front of the eismatrix will those adaptors work on the smaller 3 pin rgb ports?
It was an idea to use them for some LED Strips, but until now, we don`t use that connector for any of our products. Maybe later we will have products for this connector.
