AitkenAcorn
Heeelloooooo friends
I Am looking for a little advice before i start purchasing all the parts.
I have attached a picture of what i imagine the set up is going to look like, ignore the dual gpu its no longer like that ;-;
Im looking to do the gpu in the loop up the front i was thinking a 360mm radiator and a 120 at the back like you see in the picture already, I would also be adding a ram cooler into the loop and was wanting some additional advice on how i should set it up and what kinda pump or alternatively a distro plate but im a little confused how those would need to be configured or if it would even work with what im aiming for.
I would also be looking at the possibility of adding the cpu into the loop and replacing radiator on top with a 480 if it fails at any point.
I Also have a few questions about about what the st and hpe mean on their radiators and is there much cooling capacity difference between 20 30 and 45mm thick radiators?
Thankyeee
Thankyeee
