Siochain
Hi,
Just got a reply stating that the below temps are in spec with a Delta of 20-30°C . The hot spot was intitally reaching 110c, got it down slightly lower, but still hitting the thermal limit of 88. If I was to increase mounting pressure around the core any more, I may damage the Die. My water temp when I benched this was at 24c, is an actual delta of 64.7.
Is support actually reading the emails?. I've been advised to increase my Rad area, flow rate or fan speed. I have 2 60mm 420mm rads and one 480mm XT45. with a flow rate of 170l/h. Fans wise there are six artic P14 pwm at 900 rpm, and 4 Phanteks T30 at 1200 rpm. As much heat as the 4090 dumps, I have more than enough capacity to cover this and a 7800X3D (sips power)
Is that a real reply I got, so I do I have to wait another week for another nonsense reply. Love Alphacool products, but I'm finding your support seriously lacking to be honest.
