hello.
since eiswolf 2 for 3090 founders editions will not exist . i plan for this summer to go for a full custom watercooling.
cpu : amd 5900x
gpu : rtx3090 founders edition
case : fractal design meshify 2 xl
i never had a custom wc so i'm a total newbie in this. my case can handle 2 420 rad (1 front 1 top ) so the clearance will not be an issue.
(i already have a 420 aio but it's from another brand so i can't reusing the rad )
so i need to know what will i need to build my wc from scratch. the only thing i have is a lot of good 140mm fans (12 in my case right know and somes for backup)
(i precise i would like soft tubbing since it's easier and i really don't care about the look i only care about the cooling perf)
thank you
cpu : amd 5900x
thank you
