GMateusz1992
Hello everybody. I would like to ask you, how to proper connect, a pump from Eisbaer Aurora 420 set, to my Z490 Aorus Master mainboard ? I use Noctua NF-P14S Redux fans on radiator, so i don't need RGB controlling. I just want to make sure that the pump is running constatntly at 12V and 100% RPM. Should i use a Aurora controller and plug in a SATA power cable to PSU, or connect a 3 pin connector to a 4 pin CPU FAN header or 4 pin SYS FAN 5 or 6/PUMP Header ? Should i change some BIOS settings (changing PWM to DC) ? I also have BeQuiet DarkPower Pro P11 750W PSU.
