Hello,
I am getting ready to install an Eisbaer 280 Extreme (black edition) and have a few questions. i will only be cooling the CPU, A Ryzen 3950X
1. What coolant comes prefilled from the factory? CKC? Tec Protect?
2. Comparing the Alphacool coolants, which one has the longest system life?
3. Can I install an inline coolant sensor at one of the ports on the Eisbaer main unit? (I would like to control fan curves based on coolant temp)
4. What is the recomended coolant change interval for the Eisbaer Extreme 280?
5. What speed setting on the pump is recommended for CPU only and no additional radiators?
Thank you!!
Thank you!!
