Eisbecher Aurora D5 and 90 fitting leaking
Lightning_Touge
Hi,
I've sent a support ticket but as I didnt get any kind of confirmation I'll write here.
After assembly of the loop, left it running for 30 minutes with PC completely unplugged and the 90º fitting started leaking from the rotary part of it, not the G1/4 or the hose connections. After taking out the 90º fitting it looks like it has a machining defect on one side.
Drained the loop and replaced the 90 with a normal fitting (looks bad, actually the whole loop doesn't look great, it'll be changed soon). Left it running for 30 minutes, no leaks so I connected the rest of the PC up and let it idle for 30 minutes, coolant temp kept at 22C.
Now the main issue is, I left a game running and as the coolant temp rose (peaked at 34C) a leak formed in the pump/res combo.
I mounted it up straight from the box.
Do I need to RMA it?
I'm attaching pictures with descriptions for both the fitting and the pump/res combo.
PS: I've flushed the rads before installation with regular destilled water.
PS2: The liquid used is TecProtect 2.
Edit: Added peak coolant temp.
Lightning_Touge
Sorry to bump this after just a day. Don't want to be rude. Just wanted to have some answers/sugestions before the weekend so I can plan to empty the loop.
Also, order number is 30188867.
Edit: Loop order is pump -> GPU w/ temp sensor on the top plug -> CPU -> side rad -> top rad -> res.
Edit2: Added pics of the defective fitting.
Thanks in Advance.
The leak in the pump should be easy to repair. This is probably due to an incorrectly inserted O-ring. However, I would react quickly here, because if the water flows into the pump's electronics, it is immediately defective.
The connections are a different matter. You will have to replace them. There's nothing more you can do. The inner O-ring will be torn. That's annoying. Please contact the support team directly: info@alphacool.com
Please include an invoice.
Lightning_Touge
I understand, I'll drain and re-fit the o-ring on the res. But is it possible for AC to send me replacement o-rings just in case these have an issue ?
Lightning_Touge
This morning I've drained the loop again and after the water was out I could see the LED strip is very oxidized now...
The PC has been off since the assembly day when I noticed the leak so I don't know if the LEDs work or not.
Lightning_Touge
Thanks for the help. They replied earlier today to my initial ticket so I'll be taking this via e-mail. I'll give feedback on the solution after it's done.
Hard to say at the moment. You only wrote on Friday and nobody works here at the weekend. Of course, we always have a lot more emails on Monday. Please be patient a little longer. You should have an answer by tomorrow.
Lightning_Touge
Actually I created the initial ticket on Tuesday which was only answered on Friday after posting on the Forum. But I understand.
Interesting, we have only one open ticket left from tuesday and that is not about fittings. Strange. Can you write please directly to: info@alphacool.com?
And can you please sent me the mail adress you will use over PN? Then i can check that you will get a faster answere.
PS: Ah no wait, i can see a mail from friday.
Lightning_Touge
Ah, ok got scared there for a moment xD. The fitting isn't even my main concern, it's that I don't have a pump/res as I don't want to risk more damage. PC has been down since Monday when I assembled it and noticed the leak on the reservoir.
Lightning_Touge
Private Message sent with my e-mail address.
Lightning_Touge
Just a final update on this. The RMA process is complete and the loop has been running for 2 weeks.
I have to say, and please don't take this as a negative critic, the RMA process although simple was slow (Jan 28 till Feb21).
The lab work was very quick but the e-mail responses is where the bottleneck was.
Then the parcel had the wrong address on it (luckily the UPS guy was nice enough to call me), I reckon it's probably something weird on the UPS form because the initial DHL delivery was fine.
Anyway in the end I'm happy with the producs, got quite scared reading through the forums with 7900xtx blocks performing poorly but I can't relate, mine maxes out at 70C hotspot under a 430W load at 34C liquid temp.
Even with the hiccups I want to thank everyone at alphacool involved in the exchange for honoring the warranty and being nice every step of the way.
I'll post pics in the build thread when I fix the airflow issue I'm having.
First, I'm pleased to hear that the temperatures now look good.
Regarding support, yes, we are currently very slow in responding to customer inquiries from the customer's perspective. This is unfortunately due to two reasons. Firstly, the number of inquiries has exploded this year. Especially technical questions about our products and questions about the new graphics card coolers have surged. But in general, interest in us seems to have increased dramatically.
By now, two additional departments are helping with answering emails, but we are still unable to get on top of the backlog. Normally, our goal is to respond to emails within 48 hours. However, that has become absolutely impossible at the moment.
We are currently doing everything we can to get a handle on the situation.
llewopw
I have the same problem that Lightning_Touge had. I only get a leak when the pump is running at more than 50% PWM. Is there supposed to be an o-ring just under the glass tube on top of the plastic piece? I sent a support request on the main shop page, but I could send something to the email you've posted above as well. Any thoughts?
Lightning_Touge
I disassembled my res yesterday to clean it (the non defective one) as I was moving to a new case. There is no o-ring below the glass, there's only 2 o-rings on the side of the glass.
I guess what was happening to me (and probably you) is that one or both o-rings are bad. It's best to just RMA it as my second one is fine even after me opening it up to clean.
Just to avoid pressure build up I'm now using an exhaust valve on the top of the reservoir. It's not needed but gives some peace of mind.
