Hi there!
Yesterday I had a real worst-case-scenario and my cpu block (order no. 30143345) started leaking. I bought it back in Nov 2021 and had it running without any problems for over a year - then it started leaking out of nowhere. Thankfully I realized it just a few seconds later, plucked the power cable and hopefully dodged serious damage on my components. I can rule out installation mistakes from my side as it's not my first build and I thorougly tested it after building & had it running for a long time before this happened. Also the position of the leaks doesn't overlap with anything that I could have done.
Here are two videos that show the issue:
I'm out of ideas as to why this happened. I already tried tightening the screws of the bottom plate but it's still leaking like crazy. (You can see it leaking from the screws in video 2 where I tested blowing into the opening while covering the exit - tightening the screws seemed to help but as soon as the pump runs it leaks again)
What could have caused the issue? Could this happen again in the future after replacement?
I'm worried and hope nothing expensive died because of this.
Thanks in advance.
Thanks in advance.
