Alphacool today presents the Eisstation DC80 AIO Power Unit. The DC80 pre-filled Eisstation fulfils 2 important functions that make the expansion and maintenance of Alphacool's Eisbaer & Eiswolf All-In-One solutions much easier.
It can be used as a filling aid or as a booster for more pump power. As a filling aid for the Eisbaer or Eiswolf, the DC80 Eisstation can be connected directly to the AIO via the existing quick-release fasteners. For filling, the large G1" screw plug is opened and the integrated DC-LT 2 pump provides sufficient pressure to pump the cooling liquid into the AIO.
The expansion of an Alphacool AIO with several components can quickly lead to the existing DC-LT 2 pump reaching its performance limit. With the integration of the Eisstation DC80 Power Unit, you get more power thanks to the additional DC-LT 2 pump, so that you can easily operate a larger loop.
Click here to buy: Alphacool Eisstation DC80 AIO Power Unit
Technical data pump top & reservoir | |
L x W x H | 50,62 x 50,62 x 77 mm |
Maximum working temperature | 60 °C |
Connections | 3 x G1/4“ |
Pressure tested | 1,5 Bar |
Technical data pump | |
Speed | 2600rpm |
Maximum head | 0,95 m |
Maximum flow rate | ca. 75 l/h |
Power connection | 3-pin fan connector |
Technical data quick release coupling | |
Material | Nylon |
Tube size | 12,7 / 7,6 mm |
Technical data tube | |
Material | TPV (EPDM/PP) |
Length | 43 cm / 9 cm |
Working temperature | 50 to +155 °C |
