Eiswolf 120 GPX Pro & Eisbaer 420 CPU & NexXxoS XT45 Nova Radiator 1080
Mija67
Hello,
Evrithing is in the title. I want to ask what i need for adding NexXxoS XT45 Nova Radiator 1080 to
my Eiswolf 120 GPX Pro & Alphacool Eisbaer 420 CPU.
What attachment i need to do that and if i need one extra water pump or not.
Thank you for your answer and thank you for all this great products you selling.
Best regards
Michael
For using a Nova radiator you will need a pump, a new reservoir with pump top, new fittings and tubes. So a complete DIY setup.
Hello,
Thank you Eddy i realy appreciate your answer and i thank you for the advice.
I am earlier manual than cerebral and i want ask if you can make me a list whit all
this product what i need to make this project functional.
Best regards
Michael
Hi,
well, i can tell you only what i would choose, but you have different options.
Tube: https://www.alphacool.com/shop/schl...2-7/7-6-black-matte-3-3m-10ft-retailbox-330cm
But you can choose any type of tube you want. I prefere TPV tube because we are also using it for Enterprise customers and its one of the best tubes i know.
Fitting set: https://www.alphacool.com/shop/ansc...aubtuelle-tpv-12-7/7-6mm-gerade-black-6er-kit
6pcs are enough. I like the nylon fittings more than the brass version because they are lighter and they have a barrier ring in the connection. It is almost impossible to pull the hose off the fitting when it is correctly installed. This is extremely safe. I am using this fittings in all of my privat PCs.
Reservoir + pump combination ..... there are different options. Its up to you wich ne you like to use. Prices and optic are different and i would choose versions with a VPP or DDC pump. A few examples:
- https://www.alphacool.com/shop/ausg...nkl.-1x-alphacool-eispumpe-vpp755-v.3?c=20600
- https://www.alphacool.com/shop/ausg...l-rgb-acryl-inkl.-eispumpe-vpp755-v.3?c=20620
- https://www.alphacool.com/shop/ausg...tion-ddc-inkl.-alphacool-laing-ddc310?c=20618
Liquid: https://www.alphacool.com/shop/kueh...7021/alphacool-tec-protect-ultra-clear-1000ml
I would choose 2 bottles. 1 maybe is enough, but if you need to fil it again because of some reason, its better to have a second bottle.
And the Nova Radiator. But you need to go out of the case with the tubes. So maybe a bulkhead screw would be nice to have. Something like that: https://www.alphacool.com/shop/neue...ttverschraubung-kurze-version-g1/4-deep-black
But than, you need 2x 6pcs packages of the TPV fittings.
Hello again ,
Thank you very much for all this advice and list of parts.
What i still need to now which fitting i need to conect Eiswolf and Eisbaer to
the system , view that I have only quick extension kit or i must remove all
quick extension and replace whit tpv tube.
Best regards
Michael
The Problem is, that the NOVA Radaitor dont fit "in" a case, so the extension sets are not long enough. BUT..... you can make your own extension sets without make everything new.
For example this tube: https://www.alphacool.com/shop/schl...2-7/7-6-black-matte-3-3m-10ft-retailbox-330cm
And this QDC (you will need minimum 2 of this): https://www.alphacool.com/shop/ansc...lusskupplungsset-tpv-eisbaer-kompatibel-black
And you will need that TPV fittings (6 pack wich is enough).
Than you can make the tube as long as you need and you can connect it with the AIOs over the QDCs.
Back
