TotalControl
Received my AIO yesterday and was amazed at the quality firstly, everything seemed simple and easy to put together, installation was fantastically easy.
Then I turned the PC on. VRAM temperatures easily hit 100°c and when I loaded a game the coil whine was unbearable (see linked video)
Assuming id done something wrong I dissembled to find none of the thermal pads were making contact for the VRAM and even the pads on the backplate were barely touching the components (everything was screwed as tight as possible) I took some time reading forums here and googling other peoples issues and found what I believe the issue might be, my 3080 was one of the very first batch to arrive in the UK last September when I was lucky enough to purchase on launch day. It sounds like the GPU die on early batches are slightly higher?
I removed the included thermal pads and replaced them with the ones on my stock cooler (photos below) sorry I didn't get photos of the included white ones, but you can see the difference in thickness and the stock pads do make contact with the cold plate now but the VRAM temperatures have not improved and the coil whine was so bad it forced me to take everything apart and replace the stock air cooler.
Purchased from Aquatuning in UK, I've applied for a return but I wondered if there was anything else I could try before returning, many thanks.
Video of coil whine noise
