Eiswolf 240 GPX Pro and NexXxos GPX - AMD RX Vega M05 compatible?
mungfusensei
I'm wondering if it's possible to take the pump and rad from the Eiswolf and stick it on the Nexxxos Vega M05, so that I can have a Sapphire Nitro+ Vega 64 with a nice tidy AIO. I'm trying to squeeze it into an mITX build so having a seperate pump and resevoir would be too much.
And if it is possible to mix these two together, would it be possible to order them configured as such?
HI,
I am sorry it is not possible to mount the GPX Pro on a GPX water block. The dimension of the GPX Pro are bigger then the GPX version and the cooper plate is also mounted different.
Back
