I have a Zotac 2080 that I would like to add water cooling to reduce noise, as the stock fans need to spin too fast creating a lot of noise.
The issue is this video card only has mounting holes 70.5mm apart, which is standard distance for back plate but not heatsink mounting.
I was wondering if there is a version of the Eiswolf 240 GPX Pro that uses this 70.5 mm spacing for mounting to the video card instead of the standard 58.4mm spacing.
Thank you.
Thank you.
