Granville
Hi All, I saw in some diagrams that it is possible to unscrew connectors on the AIO GPU and CPU setup's and run them in a big loop. Could anyone give me any advice on the sort of improvements that you may get by doing this?
How does it work when disconnecting? Is there some kind of witchcraft to keep the water inside the loop, or is there chance of water egress while I am doing it?
So what I am considering is on a P600S having 360mm rad on the front of the case as intake, then 360mm on top as exhaust. Is that going to be a fairly optimal setup?
