Crazyw0lf
Hello, I recently got a eisbaer 420 from my uncle as it was extra over from ordering the wrong size for his case (oops ).
So i was looking at using it myself, but as it was semi modular i was thinking of adding a eiswolf and a helix reservoir using some extra quick connects as i think this should work?
But now i found a bit of a problem and im wondering if the list just isnt updated on my card or if they really are different?
I got the "Zotac Gaming GeForce RTX 2080 AMP Extreme Core, 8GB GDDR6, HDMI, 3x DP, USB-C ZT-T20800C-10P"
On the part checker and on the pdf list i only see the old icewolf cooler wich isnt made anymore, is my card really so different that the icewolf 2 wont fit?
Was also wondering what i should expect from using a system and setup like this.
In full spec i was looking at a eisbear420 linked to a eiswolf 240 and a helix reservoir to give it a little more water in the loop. CPU temp i can take a geus at as now im using a different 240aio cooler and i get around 70c stressed wich might drop a few degrees from the bigger radiator but not much i geus, what im wondering about if how good does a icewolf work? On air i can get my card to run 60-62c in games overclocked to 2000mhz on 100%fan wich is well LOUD I am hoping to get that temp even lower or atleast the same on less noise, would love to run sub 60c but im not sure this a pipedream on AIO or not?
2nd thing im not sure about and not sure how it works as it is advertised to be used as this is .... the icebaer has a pump and the icewolf has a pump... do you run both or one? Wont 1 pump damage the other in the long run from slight rpm differences and maybe even shape?
