Eiswolf Radiator Bolts for Low Profile Fans
486Rewind
Hello, I have the Alphacool Eiswolf GPX-Pro for the AMD RX 5700 XT to help cool the card due to the reference cards design shortcomings.
I'm going to need to replace the included stock fans for Noctua low profile fans due to my case size being so small (Corsair 220T) while test fitting everything i have come across an issue of the included screws being too long and I need shorter screws to make it all work to screw the fans to the radiator.
I have included photos to show the length difference if anyone has any advice/were to buy it would be appreciated.
How thick are the fans? 10 or 15mm?
For 10mm you will need M3x15 screws for a 15mm thick fan M3x20 screws.
expanding on this, you can buy a variety pack of m3 screw lengths off amazon pretty cheap if your local hardware store doesn't have any
Back
