ES Geforce RTX 4090 Serial Number Compatibility Check
jshbrntt
The Alphacool ES Geforce RTX 4090 Reference Design with Backplate mentions in its description that with INNO3D cards there are two different PCB designs and one of them is not compatibility with this water block.
ATTENTION! INNO3D uses two different PCB layouts.
Check the compatibility of the layout here: Layout Check
Attention: Unfortunately Inno3D is using two different PCB Layouts. Please check your serial number. If it looks like following, it is not compatible with our water blocks: 32-879-xxxx8xxxx
I have found a card with the following serial number.
32-879-xxxx8xxxx (Incompatible serial number)
32-879-220901065 (GPU for purchase)
Which matches partially but differs on the last number (where the fifth digit is not 8), does this mean it's using the compatible PCB design or not?
Vanzin
Hi,
the GPU for purchase is com patible with our water block as you can check in the serial number which is not matching.
