With the NexXxoS XT45/UT60 Dual-Flow radiators, Alphacool is once again expanding its range of high-performance all-copper radiators.
The NexXxoS XT45/UT60 360mm Dual-Flow radiators have been specially developed for use in servers. A new feature is that the dual-flow radiator based on Alphacool`s X-Flow technology is split in the middle and this consists of two smaller X-Flow radiators. Due to the limited space in servers, the use of multiple radiators is often not possible. With dual-flow radiators from Alphacool, tubing can be routed easily and, depending on the scenario, it is even possible to create two separate water loops.
Click here for further information: Alphacool NexXxoS XT45/UT60 Full Copper Dual-Flow 360mm radiators
| Technical data | NexXxoS XT45 Dual-Flow | NexXxoS UT60 Dual-Flow |
| L x W x H | 415 x 125 x 45mm | 415 x 125 x 60mm |
| Material cooling fins, cooling channels & prechamber | copper | copper |
| Material outer housing | steel | steel |
| Fins per Inch | 12 | 12 |
| Threads | 12x G1/4“ | 12x G1/4“ |
| Fan size | 120 mm | 120 mm |
| Fan slots | 3 one-sided / 6 double-sided | 3 one-sided / 6 double-sided |
| MSRP | 109,99 € | 132,29 € |
