Expanding Eiswolf 240 GPX Pro for 5700 XT
Tremelai
I'm exploring expanding the loop to include a block for the CPU and a larger radiator. Possibly multiple radiators.
My CPU doesn't need much cooling, a non-OC'd R5-3600 so I'm looking at a thick 120mm or another 240mm. (My case can fit both options.)
My question is the pump on the AIO. Is there a pumpless GPU block that can replace the pump/block combo? Dual pump possible? Is this pump adequate for dual radiator and CPU block? Or do I need to get the Aurora GPX-A block and discard the AIO combo?
Thanks!
This AIO is great by the way, regardless the GPU AMD or Nvidia. I recommend it highly!
Back
