First loop low gpu temp high cpu
mauro01
Hi all.
I was wondering if it is wrong to connect it like in the photos. GPU temp stays at 50 degrees in cinebench24 but CPU goes up to 99 after 10 sec of testing.
i7 14700KF
RTX 3080
MSI Pro Z790-P
Alphacool Core 1
Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 GameRock
HI,
as I can see you have completely mounted the IN and OUT wrong in your system and created a parallel loop. Please connect IN and OUT correctly in your loop. You have to go from the OUT of one component to the IN in the next component and not from the IN of one component to the IN in the next one,
HI,
Hi
Thank you for your advice. I've now connected it correctly but seam to have something with the cpu block. I have very little flow out of it so maybe it's got blocked with dirt. The GPU block and radiators are not new ones and I didn't clean them, so now I'm gonna dismount everything and do it the right way
Back
