First watercool 7000D build
MamaKinniku
Originally got an eiswolf 2 for my 4090 founders because the original cooler had a vapor chamber leak and wasnt cooling at higher loads anymore. I found the eiswolf 2 aio open box at modmymods and decided to get it since a original cooler was the same price. I was going to get an Eisbaer to replace my cpu cooler and join those 2 together. Last minute i decided to change into a full loop and changed my eiswolf 2 into a stand alone block with the https://shop.alphacool.com/en/shop/...7-alphacool-gpu-terminal-flat-straight-acetal since and taking off the pump terminal.
Since the eiswolf 2 radiator is just a regular 360mm radiator I used that and got an extra 420mm xt45 and a 140mm 30mm thick radiator to add to the loop. I also got the Core 200 reservoir as well as the core 1 for the cpu. Got the extra tubing and the fittings and went to work learning and figuring things out.
Originally I finished the build but wasnt happy with the layout and where the drain was.
When i got the small radiator I added it in the exhaust and redid the loop and flipped the front and put the drain at the lowest part and I am happy with it.
